02-09-2024, 01:49 PM | #23 | |
Rep 1,929
Drives: Here and There
Garage List 98 Lexus LS400 [10.00]
16 Toyota Land Cruiser [10.00] 97 Toyota Land Cruiser [8.33] 11 BMW E90 M3 Stripper [10.00] |
02-09-2024, 02:14 PM | #24 |
18326
Rep 9,410
Your driller will also test the water once they hit it? I think I would want that done before they installed the pipe and well head. Certainly don't need to pump non-potable water out of the ground.
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
Llarry20389.00 |
02-09-2024, 03:40 PM | #25 |
sportscars only
3436
Rep 3,258
Oh, it doesn't bode well for noobs like me when you have an expert at home and she's had enough of trying to purify the well.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
vreihen1619185.50 |
02-09-2024, 06:25 PM | #26 |
Rep 1,929
02-09-2024, 06:35 PM | #27 |
Recovering Perfectionist
19186
Rep 982
Key word is RETIREMENT house, and I don't blame her for not wanting to do one of her many former careers.....
Currently BMW-less.
tranquility3435.50 |
02-16-2024, 12:23 PM | #28 |
Rep 1,929
As a follow up, we drilled today.
265 feet and 20 gallons a minute. |
02-16-2024, 05:20 PM | #30 |
Rep 18
160 feet down for my well, going on 23 years. Replaced pump once. Make sure you get a big enough pump to support lawn irrigation. I have a big yard with 22 zones and have run a 1 HP pump since the get go. My water is iron free, but I do have manganese that has to be run through a softener designed for it. I also use a regular salt-based softener. If the well hits water shallow that has bad iron, they can keep drilling and often find better water deeper. Make sure you use a good-sized pressure tank, it helps with the softening. Good luck!
02-16-2024, 05:53 PM | #31 |
Rep 1,929
02-20-2024, 11:26 AM | #32 |
18326
Rep 9,410
Cost me ~$60 to re-cover the abandoned well at my dad's cabin this past weekend. 1/2 sheet of plywood, some deck screws, and a pint of mis-mixed leftover paint at the hardware store. I DID have to shovel a metric-fak-tonne of roof slide snow that fell on the old cover and broke it. I've seen wood that came off a 17th century galleon that was in better shape than that previous cover.
Our shared home well is at ~45 feet right now, with all the rain SoCal has been getting. Pressure tanks need care, painting/inspection about every 5 years.
vreihen1619185.50 |
04-12-2024, 06:19 PM | #33 |
Rep 1,929
Curious on best approach here. New well has been doing great. Sediment filter has been getting worked out with my third one about to go in. Cool water seems to be where we need it. Hot water is still coming in brown, telling me we’ve got it in the two hot water tanks.
Is there a best practice to flush? Just keep running water? We’re a couple weeks being into the new house. |
04-12-2024, 07:15 PM | #34 |
19186
Rep 982
Is your sediment filter in front of the hot water heater(s)? If so, the hot water should be as clear as the cold water.....
Currently BMW-less.
spazzyfry1234645.00 |
04-12-2024, 07:48 PM | #35 | |
Rep 1,929
My assumption is that the hot tanks are holding sediment that made it past the filter whereas just constant use flushed anything out of the cold lines. We've got two 50gal tanks. We've certainly ran enough to get it out, so something is just "stuck" in there. Wondering if there's a flush option. Brand new everything. |
04-12-2024, 07:59 PM | #36 |
19186
Rep 982
I would stop after the quick flush if both tanks are new and the water runs clean out of the drain hose:
https://www.thespruce.com/how-to-dra...heater-2719055
Currently BMW-less.
04-14-2024, 02:29 PM | #37 | |
Rep 1,929
Drained the second, drained the first. Filled them both back up. Drained the second and flushed the second. Drained the first and flushed the first. Both showed clear water. Filled back up and turned the heaters back on. Back to brown hot water again. Cold is still clear. I’m lost. Calling well dudes tomorrow. |
vreihen1619185.50 |
05-10-2024, 05:44 PM | #38 |
sportscars only
3436
Rep 3,258
I've come to realize that given the replies here, esp from someone whose spouse is a water expert and wanting to take a break, that I'm just gonna leave this water thing to the city.
Septic tank is the furthest I'm going to go, I don't have a prb w stuff exiting my home but coming in is another story haha.
vreihen1619185.50 |
05-12-2024, 05:48 PM | #39 |
19186
Rep 982
Ironically, my DW and I just returned from a short trip down to our tree farm. Met with a soil engineer, to draw the septic system and leach field designs for the state permit. Being on the lake, the requirements are a bit stricter to keep both runoff silt and effluent from reaching the shore bank.....
Currently BMW-less.
05-13-2024, 11:44 AM | #40 | |
18326
Rep 9,410
vreihen1619185.50 |
05-13-2024, 12:34 PM | #41 |
19186
Rep 982
That's *not* a Baby Ruth bar floating in the lake!!!!!
Currently BMW-less.
spazzyfry1234645.00 UncleWede18326.00 |
05-13-2024, 12:37 PM | #42 |
Rep 1,929
Coincidentally enough I just had a full home water filtration system installed for our well. Plumbers left about an hour ago
05-13-2024, 12:57 PM | #43 |
Rep 3,024
Avoid the pressure tank and spend more for a constant pressure pump, e.g. Grunfos, 15SQE10-250.
It's like having public water. Make sure to have the well company place the pump wires inside of plastic conduit (the same black piping they use to protect the wire underground from the pump to the house. When the pump spins up it rubs the wires against the well sleeve and in my case after 9 years wore through wire's sleeve and shorted out. |
06-05-2024, 08:10 AM | #44 |
Rep 1,438
