11-09-2011, 01:31 AM | #199 | |
///M-fanatic
196
Rep 3,885
11-20-2011, 03:23 PM | #200 |
Rep 688
19" rims
ok i have been reading this for at least 30 minutes and am more lost than when I started. I am going to go to 19" rims for the DD wheels after the first of the year with width of 8.5 and 9.5. I am running stock suspension and camber. I am leaving it that way for forseeable future. I don't want to run any spacers or roll the fenders. what is the best offsets I need on the 19" rims? OR can 9" fronts work without rubbing? If I go with the 9" fronts I will go with 10" rears
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor Last edited by TexasZed4MC; 12-09-2011 at 09:41 AM.. Reason: typo and additions |
11-20-2011, 05:52 PM | #201 |
M = Midlife Crisis
67
Rep 2,006
ET32
ET25
2006 Z4MC - #LL93158
11-28-2011, 05:42 PM | #202 |
Rep 34
hi guys ,
i'm new here I have a z4 m coupe and I must do an order for a set of vmr v701 wheels 18". the problem is this the front I have decide to fit 8.5 x 18 et 35 and it will fit good without rubbing but i'm not sure for the rear .... 9,5x18 but which et???? vmr advice et 22 but I must fit 255 40 18 tires and when I will fit a bilstein pss10 I think it will rub so vmr give me the option of et 33 and for sure I am inside the fender ......... what do you advise me to choose for the rear et ........ please help me ..... thanks
VINCE CHI SI RIALZA UNA VOLTA IN PIU...!!!!! |
11-28-2011, 06:50 PM | #204 | |
M = Midlife Crisis
67
Rep 2,006
ET32 ET25 Is a comfortable setup - Much depends on the brand of tyre you choose.
12-16-2011, 07:22 PM | #206 |
Rep 688
Front 19"x8.5" et 30
and Rear 19"x10" et 22 will these work? I have a set in mind but this is their limitations
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor |
12-16-2011, 07:41 PM | #207 |
M = Midlife Crisis
67
Rep 2,006
Rears may be tight. Tire brand and size needs to be considered.
12-17-2011, 07:13 AM | #209 |
M = Midlife Crisis
67
Rep 2,006
Using the wheel calculator the rears will EXTEND an extra 21mm from stock.
When I used 12.5mm spacers with 265's I had a minor degree of rub with the OE wheels. Lowered ~ 1". If you choose the right tire you may be OK.
12-23-2011, 08:34 AM | #210 |
Rep 752
I ran 19x10 et25 with 275/30 RE-11s in the back with about 1/2" drop and -1.7° camber. There was just a very very minor rub on the top edge of the tire on high compression highway dips but was fine other than that. This makes me believe that this may ne as far as you can push the rear before you have issues. I used this setup for a year at tracks and driving to/from (as far as 800 miles one way to some tracks) and was happy with the setup.
My local body shop said rolling the lip on the back fender is risky (paint crack) and not advisable (the fender liner sorta rests on it. So they did a very subtle 'pull' on it to get that little bit extra clearance. Just a word on advice to anyone thinking of rolling the rear fender- be very careful. These fenders dont take rolling well from what multiple reputed shops told me. |
12-23-2011, 12:23 PM | #211 |
Rep 109
I am sorry.. I have looked and looked and I just cant find it...
Stock rear M coupe wheels... what is the widest tire I can put on that before it rubs or I sacrifice performance? (I assume that 40 is the best height?) I currently have 265 40 18 hankook ventus v12's and they seemed ok.. (literally only lasted me 6000 miles... but I also ran them pretty hard and did a smoke out session or 2) so again, Stock rear M coupe wheels... what is the widest tire I can put on that before it rubs or I sacrifice performance?
2007 Z4M Coupe - 2010 Ducati 848 - 1968 Mustang 302 Last edited by TriAdX; 12-23-2011 at 02:44 PM.. |
12-24-2011, 01:32 PM | #212 |
Rep 5,329
wondering what we all think to the 18" e92 m3 oems would be like...
fronts have et 29 8.5" the rears are a perfect et23 on a 9.5" rim.... id think that these would be fine with lots of front camber, say -2.8 ish??? i think these would look PERFECT!!
12-24-2011, 01:55 PM | #213 |
Rep 924
For those who are curious:
I'm currently running Rear 19x9.5 ET20 275/30 with .85" drop and there is no rubbing. Does anyone have experience with a Front 19x8.5 ET32 or more aggressive offset? My next set of wheels is this and I want to know if there are issues with that offset on stock camber.
12-24-2011, 02:34 PM | #215 |
Rep 924
So you don't think 3mm more stick-out will be an issue? I currently have 8.5 ET35 and it looks flush with the fender already on the driver's side. For some reason the passenger side looks more inset.
12-24-2011, 04:42 PM | #217 | |
Rep 5,329
Running -2.5.... No rub at all and plenty of space, without the camber it would rub for sure.
12-24-2011, 10:26 PM | #218 |
Rep 924
How wide of a wheel? I have zero rubbing right now with ET35. 3mm is gonna screw me?
12-26-2011, 04:15 AM | #219 | |
Rep 5,329
when i get my coil overs in ill just add alittle more camber which i want anyway so its not an issue to me....... By the way this is on using every last drop of performance driving...
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 03-05-2012 at 08:16 AM.. |
12-26-2011, 07:31 AM | #220 |
M = Midlife Crisis
67
Rep 2,006
Assuming folks are running 235's on the front with the 8.5 ET32 setup. Do research on tire brand - there is significant differences between brands on the width of the tread shoulders.
