      04-16-2011, 10:44 AM   #45
AlphaM911
AlphaM911's Avatar
Drives: 2005 Acura RSX-S
Originally Posted by bat1959 View Post
Thank you . Is there any reason you cannot leave the drain plug off or drill a hole in it for a constant drain?
Regards
Bren
^^^ This.
How often should I drain the drains?
-BJ "There's the moment you know you want one, there's the moment you first own one, and for the truly afflicted there's the decade or two that passes in between."
      04-16-2011, 11:49 AM   #46
Shipkiller
Shipkiller's Avatar
Drives: Me
Originally Posted by AlphaM911 View Post
^^^ This.
You don't drain the drains, just keep them clear of debris...
Depends on where you park. If it is normally garaged, then I would do a yearly cleaning/flushing to get the gunk out.
If it is parked outside, twice yearly..
I would not attempt to drill out the lower hole. The exit hole is larger than the pipe coming down to it.
      04-30-2011, 03:47 PM   #47
Jokin
Germany
Drives: BMW Z4 2.5i LPG
In the meantime it's no longer necessary to need some tools to unplug the drains.
Just lay beside your car and put your arm through the 4-corner-hole in the underbody right in front of the rear wheel.
Feel the rubber and pull it out with the plastic-ring.
In Germany we have many broken soft-top-engines and we created this support-site (in German):
http://www.zwiki.net/index.php/Hydraulikpumpe_defekt
best regards,
Frank
      07-12-2011, 10:33 AM   #48
TheCadd
Drives: z4 2.5 SE
the link for the PDF doesnt see to work any more.----
EDIT - > Found this one in the thread. Thanks guys http://www.shipkiller.com/How%20to%2...p%20Drains.pdf
Cheers
M.
      07-12-2011, 02:49 PM   #49
Shipkiller
Shipkiller's Avatar
Drives: Me
That link will not work..
Try this one:
      07-18-2011, 07:08 AM   #50
ljkiter
Drives: z4 35i manual
best regards,
Frank
can you rehost the pics here? The translation between english/german didn't come out quite right with the wiki
      07-28-2011, 07:31 PM   #51
afhf0508
afhf0508's Avatar
Drives: 2003 BMW Z4 2.5
Please people save your money do a drain clean now!!!
My hydromotor sounds dead, Debating to tackle the DIY or have a shop do it quoted 8 hours of labor. I'll do a clean tonight and see.
      09-24-2011, 12:49 PM   #52
tom breneol
Drives: z4 2003
can you re post the link with pictures?
can you re post? the link is no longer active...thanks
      09-24-2011, 02:03 PM   #53
Shipkiller
Shipkiller's Avatar
Drives: Me
Which one? Both that I can tell are working.
      12-17-2011, 02:12 PM   #54
JamesPdx
Drives: BMW 2003 Z4 2.5i
PDF link is dead
Originally Posted by Ale_72 View Post
Hi all,
Can someone repost this PDF? The link is dead.
Thanks
      12-17-2011, 03:57 PM   #55
Shipkiller
Shipkiller's Avatar
Drives: Me
Check now. I have been doing some server maintenance...
      05-31-2012, 02:36 AM   #56
Sothern
Drives: BMW Z4
Hi, I seem to be unable to see the pictures in the tabs below the writing. I have a drainage problem in my Z4 soft top hood compartments. I can read the text that has been given from *OP* GV from Belgium. However cannot see the pictures in the tabs below. Can anyone suggest what I am doing wrong. Thanks. Sothern
      05-31-2012, 06:04 AM   #57
Shipkiller
Shipkiller's Avatar
Drives: Me
Try this link:
http://www.shipkiller.com/Softtop_Main.html
      05-31-2012, 09:28 AM   #58
Stromtech
Stromtech's Avatar
Drives: 2004 Z4 3.0i 6-speed Sport
Originally Posted by Shipkiller View Post
FYI Shipkiller....That all works fine for me
      05-31-2012, 10:13 AM   #59
Shipkiller
Shipkiller's Avatar
Drives: Me
I moved to a dedicated site so some of the older links will not work.
      10-04-2015, 11:20 PM   #60
jjr
jjr's Avatar
Drives: 2006 BMW Z4 3.0si
Could the photos be re-posted?
Thanks
