      02-15-2011, 11:49 AM   #1
BTM
Drives: A///MERICAN!!!
Steering column appears "off" ?
I have a Z4MC, and the steering wheel seems to be misaligned. I'm not talking about off center when tracking straight, but I mean the entire wheel and column look like they come out of the dash crooked? Does anyone else see this on their cars? It could be an optical illusion, the way the dash is shaped, or simply the way I am sitting, as the drives completely normal otherwise. It is not a significant amount, and I just noticed it the other day. A very crude illustration below (birds eye view): the black line would be a column that is oriented "straight" and the red is how mine appears to look. Any thoughts? Am I paranoid? Searched extensively and couldn't come up with anything...hope it's normal...
      02-15-2011, 02:15 PM   #2
onebluemcm
onebluemcm's Avatar
259
Drives: roads less traveled
2007 E85 M  [0.00]
2007 E86 M  [0.00]
2012 E91 335xi  [0.00]
Probably paranoid, it would take a lot to make it out of alignment like you are stating. To be sure though, can you snap several pics to post up, from different points of view? Might help.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
      02-15-2011, 02:21 PM   #3
ZStig
instagram 997turbotom
320
Drives: Alpina XB7
ask the dealer to check it out for ya
      02-15-2011, 02:31 PM   #4
mousitch
Dark Sider
mousitch's Avatar
143
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
I recall seeing this issue on other forums. This is how BMW designed the car from what Ive read. If you look from the hatch or from the back all owners should notice it is offset somewhat. Many theories including safety in the event of a crash.
Here is one explanation from a different forum...
"I have looked at many many Z4's and they are all this way. Very irritating that BMW would build a car with a crooked wheel... I would be curious if there was a fix. The new Z4's do not exhibit this.
Many cars (and the majority of small cars) don't have the steering wheel perpendicular to the centreline of the seat. It is all a function of packaging, the relationship between the wheel-well, transmission tunnel and components in the engine compartment determine the alignment of the steering column shaft. In a small (narrow) car it is generally impossible to find a position that allows the steering column to be perfectly aligned with the centreline of the seat, especially if wide front tyres dictate a large wheel well for the size of the car
I've not noticed this in any car that is mid-sized and above, but have noticed it in many cars that are smaller than mid-sized."
      02-15-2011, 02:39 PM   #5
BTM
I will try and take some that show it, but doubt it will really come through in photos. I mean for it to be really "wrong" it seems either I would have to have broken suspension pieces (which I don't) or a botched repair (though the car is clean)
Next time I'm in for sure...
This is reassuring...do you have any links to any discussion? I've searched as well as I can, and can't seem to come up with much. Probably the terminology I'm using...always come up with the "you need an alignment" threads
      02-15-2011, 02:42 PM   #6
BTM
Thank you for the edit...seems consistent with what I'm having. It really doesn't affect the driving at all...just that it's in the back of my mind. That it's normal makes more sense and I can concentrate on driving
      02-15-2011, 02:43 PM   #7
doozyj
doozyj's Avatar
14
Drives: 2007 M Coupe
You mean canted. My M3 E46 was also like that and was brought up by other E46 M3 owners as well. I believe it had to do with ergonomics.
2007 /// M Coupe Alpine White / Light Sepang Bronze 6MT
2003 /// M3 Alpine White / Imola Red SMG II (Sunroof Delete) SOLD
      02-15-2011, 03:24 PM   #8
esqu1re
esqu1re's Avatar
48
Drives: M Coupe
I've noticed the same thing. At least our pedals are where they're supposed to be.
The old lamborghini's pedals didn't line up with where your feet would go when sitting in the seat.
      02-15-2011, 04:57 PM   #9
ZStig
320
Drives: Alpina XB7
and in the Viper, you're sitting sideways. hahahaa
      02-15-2011, 04:58 PM   #10
ZStig
320
Drives: Alpina XB7
I'd also look at your panel gaps by your steering wheel column. if they're symmetric, its most likely normal
      02-15-2011, 07:24 PM   #11
wrh3
Car Guy
wrh3's Avatar
53
Drives: BMW M2, Alfa Romeo 4C, Jaguar
This is how BMW has designed their cars as long as I can remember, the logic being that in a collision the column will move to one side. My daughter's E30 is the same way.
      02-15-2011, 07:43 PM   #12
RBull
It's normal. Most car steering wheels are canted to some extent. Likely has to do with where the steering box/linkage is located relative to the driver seat.
In some trucks the cant is extreme.
      02-15-2011, 07:46 PM   #13
BTM
Huh I'll have to try and take notice...drive a variety of work trucks all the time and never noticed...nor in any other car for that matter...though this one is particularly special to me so maybe it's just
My panel gaps are symmetric...at least now I know my eyes aren't deceiving me...and my car hadn't suffered some botched repair
      02-15-2011, 09:00 PM   #14
BTM
lol...I still want one
      02-16-2011, 05:16 PM   #15
RBull
The cant can often be noticed looking closely at the distance of both sides of the wheel relative to the driver.
      02-16-2011, 06:53 PM   #16
ZStig
320
Drives: Alpina XB7
gen 2 vipers are priced the same as used z4Ms, go ahead!
      02-16-2011, 07:29 PM   #17
BTM
not at what I paid...and not in my insurance bracket lol (23 single male)
      02-17-2011, 12:43 AM   #18
psygnosis
psygnosis's Avatar
25
Drives: '04 Z4 3.0i Sport
OMG I'm not crazy. I noticed this on my car. It's not extreme but just enough to feel 'off'. If it's normal I wont worry about it.
      12-03-2012, 12:02 AM   #19
EMP07
EMP07's Avatar
40
Drives: Z4M
I just noticed this on my car.
Has anyone tried to "adjust" the column? is it possible?
BSM Z4M Coupe
