      09-04-2025, 11:05 AM   #1
Crazey
Drives: 2003 Z4 3.0
New Owner. Need Direction
Hey, new owner, well got the car about 6 months ago. 2003 3.0L.
What is some good shops to shop at?
I need new head lights for sure.
Top obviously doesn't work, not planning on repairing in the near future.
What is y'all's recommendation to lower the car?
What are some things i should know about these cars? What goes out, what is a must change? etc...
I am a car guy, and i love all my cars. Z4 is the last addition. Couldn't pass it up, it was too good of a deal for a car with under 50k miles.
Currently i have:
1979 L-82 Corvette
1990 L-98 Corvette
1993 ZR-1 Crovette
1996 3000GT VR-4
1998 R129 SL500
2002 S500
2003 Z4 3.0
2013 Renntech S550
And two vans, lol. 2016 Express 2500, and 2023 Mercedes Sprinter 2500.
THank you all in advance.
Peter
      09-06-2025, 11:42 PM   #2
3002 tii
3002 tii's Avatar
2861
For oem maintenance, I go with FCP Euro (lifetime replacement). Other vendors have implemented similar policies but they were the original so I support them. For aftermarket, I cross shop between ECS (or Turner, both owned by same parent company) and Bimmerworld.
Re headlights, I would generally avoid aftermarket because the wiring on those are always f’d up. I’d rather pay up a little more for used ones on eBay. If you don’t have xenons, new halogens are little more budget friendly.
Re lowering, really depends on your goals (aesthetics vs performance). You can do simple spring & shock combo to fancy two or three way coilovers.
Despite the low mileage, I would start with flushing all the fluids (engine, transmission, diff, and brakes). Inspect belts and hoses to see if any have dried and are in need of replacement. Also check tires for dry rotting.
Buy a good BMW specific code scanner that is compatible with that chassis. If everything looks clean, do your basic maintenance and enjoy the car.
PS - if you need to cross reference part numbers, go to www.realoem.com; enter either last 7 VIN or look up your chassis by changing the catalog from ‘current’ to ‘classic’, and select Z4 / E85, engine trim, and production date.
Follow for latest mods
Resoelg338.50
      09-12-2025, 01:12 PM   #3
Crazey
Drives: 2003 Z4 3.0
I appreciate you replying so quickly. Doing pretty much everything you just listed. Just need to find a good pair of headlights.
      09-13-2025, 12:01 AM   #4
Resoelg
Resoelg's Avatar
Drives: 2023 X3M
2006 Z4M  [0.00]
2023 X3M  [0.00]
Welcome and enjoy. They are a blast to drive.
