02-07-2020, 05:44 PM | #1 |
Rep 407
Drives: Miss Daisy
Surround sound system recommendations?
My surround sound receiver seems to have taken a dump so now I am looking for a surround sound system. It's an Onkyo 7.1. New one doesn't have to be 7.1 if it's just as good. (This one is 10+ years old). Not looking to spend gobs of $. Any recommendations?
02-07-2020, 05:52 PM | #2 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
02-07-2020, 07:31 PM | #3 |
Rep 2,250
Ours shit the bed a few weeks ago. I just picked up a JBL Deep Base Sound bar with a wireless sub.
Sound bar under the tv, sub at the back of the room. Just something quick and cheap (<$400) to get the job done as we will be upgrading everything pretty soon. Actually sounds pretty good.
Everybody has a gameplan....until they get punched in the mouth.
02-07-2020, 07:32 PM | #4 | |
Smiling Politely
1383
Rep 29,118
Get last year's Denon for cheap. Pick a model that fits your needs.
02-07-2020, 07:36 PM | #5 |
Rep 407
Drives: Miss Daisy
02-09-2020, 03:46 PM | #6 |
Rep 96
Vizio makes some pretty good sounding setups, I have two and considering a third for the garage.
https://www.costco.com/vizio-sb36512...100459820.html The one thing I hate though is I cannot control the volume individually per speaker. |
02-09-2020, 04:26 PM | #7 |
Rep 4,823
I got my Denon repaired when it died. It took less time and money than figuring out what to replace it with.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
02-10-2020, 04:43 PM | #9 |
Rep 1,926
I guess it depends on what kind of setup and budget you are looking for. I have a basic Vizio soundbar with wireless sub in RV and works great for that environment. At home I have an Onkyo receiver with some Polk floor speakers I bought a few years ago. When I upgraded TV recently I added a matching Polk center speaker. Since my living room/family room is open to the kitchen in the rear I can't easily have rear speakers (I don't feel like running shit through the ceiling) but I find the setup with just fronts works fine for me.
I compared to some soundbars and unless it was the $1k range bars I preferred my setup which I already had, only cost me like $100 for the center speaker. |
02-10-2020, 06:20 PM | #10 |
Rep 1,087
Some of more affordable receivers are about $250 from Best Buys which are a lot better than something similar in price 10 years ago. It depends on your budget. If you're willing to go separates then it would be a bit more expensive but will gain in sound quality.
Are you looking to purchase speakers as well or only the receivers? I mean a proper surround sound system would probably need two fronts, one center, and two rears. If your front speakers are large enough, you probably won't need a sub. Last edited by WestRace; 02-10-2020 at 06:42 PM.. |
02-10-2020, 10:44 PM | #11 |
Rep 14,521
you can try accessories4less.com
having my Nakamichi sound bar with 2 8" wireless subs sound amazing for the last couple of months! even the wife approves over having the 2 big towers next to the TV
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
02-10-2020, 10:47 PM | #12 |
Rep 6,069
I have a 20 yo system and it still works great. Good thing is if I upgrade I just have to swap out the receiver but can keep the speakers and cable. I would look for the latest HDMI 8k support and Bluetooth audio. Dolby Atmos support. Maybe look at a budget of $400?
02-10-2020, 10:49 PM | #13 | |
Rep 14,521
02-10-2020, 10:51 PM | #14 | ||
Rep 6,069
02-11-2020, 12:01 AM | #15 | |
Rep 3,242
As far as not needing a sub, unless you really have large speakers, most everyone needs to have a sub. Since I'm thoroughly familiar with B&W speakers, a 802D3 is what I would consider a fairly large speaker. And even with the 802, I would still recommend the use of a sub. I used to be anti sub because all I was exposed to was crap sounding subs which only played loud and had boomy distorted bass. It wasn't until I heard properly designed subs that my mindset changed. Now I run subs with all my serious systems. My main system has 2 subs; a 15" and a 18". My 2 channel system has a single 12" sub. Dropping the use of a sub in a surround system is also a mistake as there is a discrete LFE channel with all multichannel audio mixes. Not only is having a sub an advantage for low bass reproduction as subs are designed with this in mind, subs help with the overall sound quality of the rest the audio system. Setting the other channels to small will alleviate the amplifier driving those speakers from having to reproduce deep bass which is the hardest load on any amplifier. Having a sub is essentially bi-amping your system. With the economization of consumer audio for the masses, I wouldn't bet a $250 receiver has the necessary amplification and power supply to be driven hard. Having a sub provides better flexibility in placing the sub in the optimal position based on your room characteristics to get the best performance/sound. Where one places a standard speaker is not necessarily the best placement for bass reproduction. Many times this is the rule and not the exception. |
02-11-2020, 12:15 AM | #16 | ||
Rep 3,242
Maybe I'll change my mind with a proper system set up for Dolby Atmos. Until I hear such a system, my feelings of Atmos is meh. |
02-11-2020, 12:27 AM | #17 | |||
Rep 6,069
zx10guy5161.00 |
02-11-2020, 12:34 AM | #18 | |
Rep 947
Back on topic.
My experience with the Denon 3313 has been very good. 7.1 and iPod capability (plus lots of other stuff. I particularly like the Audessy EQ via microphone) Available second hand over here quite easily at very low prices now (yes it’s a seven year old model). YMMV. Last edited by Techno 9000; 02-11-2020 at 12:46 AM.. |
02-11-2020, 07:44 AM | #19 | |
Rep 407
Drives: Miss Daisy
02-11-2020, 07:58 AM | #21 |
Rep 3,242
02-11-2020, 11:39 AM | #22 |
Rep 4,203
ok being serious the LG SK9Y or 10Y is pretty sweet... OR
https://www.amazon.com/Sony-Sound-Ba...language=en_US Dolby ATMOS totally worth it
