12-09-2019, 11:27 AM | #1 |
Rep 15
Drives: 2005 BMW Z4
First time installing a Pioneer SPH-10BT
I am going to attempt to install a Pioneer SPH-10BT into my 2005 BMW Z4.
I am going to use a Crux SWRBM-57K, so I will keep my steering wheel functions. I will be running new wires from the new radio to the trunk and hook up the the outside on the existing amp. My questions are, wires from radio to ?? (find location of in my Z4). LIME Green to Reverse signal input Violet/white to Parking Brake Thanks Donkman |
12-10-2019, 10:55 AM | #3 | |
Rep 15
Drives: 2005 BMW Z4
: Parking Brake : Blue/Brown/Yellow, Parking brake switch or cluster. Pin # 2 : Reverse signal input : To Blue/Yellow at kick panel or cluster. Pin# 22 |
12-11-2019, 12:14 PM | #4 |
Rep 779
Not 100% sure, but you're looking for the pin out of the line running into radio ?
see if this helps https://www.tehnomagazin.com/Auto-ra...-Connector.htm
-Roranji
12-11-2019, 02:27 PM | #5 | |
Rep 15
Drives: 2005 BMW Z4
and where to connect the Violet/white wire from the new radio to the Reverse signal . ( Only needed if using a backup camera) Last edited by Donkman; 12-21-2019 at 08:49 AM.. Reason: added info. |
12-22-2019, 07:28 AM | #7 |
Rep 15
Drives: 2005 BMW Z4
Vanne , Where did you find the Blue/White wire? did you need to disassemble the console?
PS, Vanne told me it is under the shift boot, no need to remove console. Last edited by Donkman; 12-26-2019 at 09:32 AM.. Reason: More info. |
