      04-26-2012, 05:28 PM   #1
22022
22022's Avatar
Drives: VT2-500 ZM4 roadster
Supercharged Ess z4m roadster
As requested by Beedub here are some pics.
Had it out today,i feel sorry for my rear tires
      04-26-2012, 06:18 PM   #2
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
ooo looks nice!
Nikki
      04-26-2012, 06:18 PM   #3
DataStream18
Drives: 2003 BMW Z4
Mmmm pretty!
TS2/Cat-Less Headers/Jet Hot Coating 2000/CF Engine covers & Oil Cap/RPi Scoop/Matte Black Grills/H&R Sport Springs/15mm Spacers Rear/12mm Spacers Front/Flowmaster 40 series/Alcantara Shift Boot/CF Vinyl wrap/SPEC Stage 2+ clutch/8 Lbs Fly wheel/ZHP Shift knob/Hawk HPS Pads/Cross Drilled/Slotted Rotors/Performance Pedal Set/Stewart water pump
Love is like a fart; if you have to force it, it's probably shit.
      04-26-2012, 07:19 PM   #4
dubsesd
#dubspec
dubsesd's Avatar
No_Country
7301
i love it! just powdercoat that intercooler black
instagram: @ dubsesd
      04-26-2012, 07:19 PM   #5
avsbmw
Drives: 07 Z4MC
nice! post some videos!
      04-26-2012, 10:14 PM   #6
crfine88
crfine88's Avatar
497
Drives: E86M
Awesome build!
Nice to see her out on the track too!
      04-26-2012, 11:01 PM   #7
22022
22022's Avatar
Your right, just upgraded from vt1-445 to vt2-500 and could not wait another second to try it out, it will be a winter mod.
      04-26-2012, 11:06 PM   #8
22022
22022's Avatar
Originally Posted by crfine88 View Post
Awesome build!
Thanks.
      04-27-2012, 02:09 AM   #9
Beedub
wahoooo another FI brother!! im going Vt2-50 to 550 very soon ;-)
how do you find the power??? alittle review would be awesome!!
      04-27-2012, 11:00 AM   #10
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Very nice and a fellow canuck! If you *EVER* want to part out that kit, I'll drive to Vancouver from Winnipeg and get'r done! Cool, man.
      04-27-2012, 11:49 AM   #11
Beedub
op, be very careful tracking this car with the stock brakes, that type of power will very quickly kill them....... i did one lap on my stock brakes and decided to stop until i get a BBK!!! Be safe bro...
cant wait to here your review :-)
cant you tell me any info on the boost your seeing?? AFR @ redline??
the upgrade kit for vt2-550 is tiny now your at 500 spec, more power at this point is very easy to get to... wahoooo
review please.... nowww!! lol
      04-27-2012, 12:02 PM   #12
ZStig
instagram 997turbotom
348
Drives: Alpina XB7
Car looks sinister with the intercooler poking out. Maybe paint your calipers to match the interior. Usually im not into that stuff, but it would work on your car. Maybe just the front?
      04-27-2012, 01:35 PM   #13
johanness
Drives: 2008 Z4MC
Great pics T! We met up in Vancouver and I can say it's one of the nicest Roadster examples I've seen. I wouldn't change the color of the intercooler either - looks menacing as is.
      04-27-2012, 03:29 PM   #14
Beedub
dont paint the i/c imo!! i think it looks sick silver..... then again it really shows up on your black car, on my silver car, its less obvious.... surely painting it black messes it some of its thermal qualities?? Bet you if you drop ess an email they tell you to leave it be ;-) put me to the test ;-)
      04-27-2012, 03:57 PM   #15
dubsesd
#dubspec
dubsesd's Avatar
No_Country
7301
powdercoating an intercooler doesnt have any negative affects. i just think it looks cleaner....and in his case, adds to the sinister theme/effect. kinda sticks out right now. also think the brakes look perfect oem black. unless you upgrade to a bbk, leave the stock brakes black. painting cast calipers another color than silver/black looks kinda cheap
      04-27-2012, 04:09 PM   #16
Beedub
hmmm cant agree here, powder coat is thick, having touched my inter-cooler after prolonged runs, i can FEEL the heat from it, particularly inlet side, powder-coating it black with surely keep that heat in for longer..... a quick search on good reveals numerous sites that back this theory, even if its incorrect, id sill touch base with ESS to see their opinion, if this was a non issue, im certain ess would offer this as a cost option, A) because they make easy money and B) because they offer numerous parts painted from them direct......
      04-27-2012, 04:18 PM   #17
ZStig
348
Drives: Alpina XB7
I did a LOT of research before painting mine. The only way it can hurt cooling is if you clog up the little fins with paint. ESS says you can paint the sides, but don't paint the fins. BUT there's 1/2" strips of aluminum between the fins, running vertically that can be painted. SO, I bought special radiator paint, masked off the fins, and cut out the masking tape on those horizontal bars running between them and sprayed it all with about 4 very light layers. Then I took the masking tape off, and sprayed over the fins with a single, very very light dusting.
I guarantee you that my intake temperatures were not affected. Although I would like it to be a little more visible instead of completely stealth
      04-27-2012, 04:32 PM   #18
22022
22022's Avatar
The power is very addictive,I love the serge in acceleration at around 4500 RPM. With the stock exhaust at high RPM you can really here the what sounds like a Vacuum cleaner or excess air blowing out.
I already found out the hard way last Sunday, After doing around 200 KM @ Mission raceway had to replace my new brake pads that I just installed. My boost is is around 6.5 PSI,I have a Auto meter gauge that has no peak memory so I cant be sure.
I will definitely check into it Thanks
      04-27-2012, 04:36 PM   #19
22022
22022's Avatar
Thanks Johnness,your cars pretty hot as well.
When am i going to see you out at one of our track days?
      04-27-2012, 04:40 PM   #20
22022
22022's Avatar
Thanks for the info,something that i might do this winter.
      04-27-2012, 04:44 PM   #21
22022
22022's Avatar
If i do anything with the calipers it will be an upgrade,And i would probably get them in black.
      04-27-2012, 04:49 PM   #22
fercho
fercho's Avatar
Drives: 2005 z4 2.5
hey what kind of black are your wheels?? they look sick
2005 z4 2.5i/// Aero front bumper, m rear bumper,08 rear lights, custom quad exhaust, matte black front grill, OEM alarm, llumar security film,m wheels, HID lights, LED interior and trunk light,Ipod integration, stubby antenna,tein s-tech springsx
