08-23-2011, 09:18 AM | #1 |
Rep 615
Maintenance prior to HDPE
Other than changing the brake fluid (which I did last weekend), are there any other special maintenance items that need to be done before doing a 2-day HDPE? If the oil was changed 3-4 months ago, should this be done? My inspection I is due in December. Pads and rotors are only a month old so they should be fine.
Thanks for the input
08-23-2011, 09:36 AM | #2 |
Rep 11,669
Here's an inspection form that our local club uses.
http://trillium-bmwclub.ca/sites/tri...ectionForm.pdf
08-23-2011, 10:44 AM | #3 | |
Rep 615
08-23-2011, 11:02 AM | #4 |
Rep 11,669
oil will be fine.
I'd rather change it post HPDE
08-24-2011, 08:22 PM | #5 |
Rep 753
This is what I have been doing for the last 3 yrs and 10 mos of ownership and regular HPDEs -
- Bleed brakes before every event if on stock brakes - Change the oil after 2-4 track days (HPDEs) or about 4000-4500 miles (if no HPDEs). - Every 20K for rear diff fluid - Every 40K for trans fluid The last two are good whether you do HPDEs or not but important when you do. |
08-25-2011, 12:22 PM | #6 |
Rep 12,570
In addition to everything above, check your lugs are properly torqued down and check your tire pressure.
08-26-2011, 10:33 AM | #7 |
Rep 224
Sept 9-11 at Hallett I assume? I'll see you there!
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI 97 M3 Coupe (Track)--95 BMW M3 Coupe 91 BMW 850i 6MT--20 Ram 1500 16 Chevy Tahoe 4WD |
08-26-2011, 10:25 PM | #8 |
Rep 615
You are correct. I hope we get a break on the heat by then.
