10-22-2022, 07:51 AM | #1 |
Rep 33
High performance aluminum radiator upgrade for Z4M
Looking for high performance aluminum radiator upgrade for my Z4M roadster.
Recommended pair number by CSF or Mishimoto? (direct fit) |
10-24-2022, 02:57 PM | #4 |
Rep 5,329
Zionsville do a very high quality piece but its not cheap.
10-24-2022, 04:05 PM | #5 |
Rep 801
Ouch, $1100 for a rad.
https://www.zionsvilleautosport.com/...inum-radiator/
2008 E86 M coupe
10-25-2022, 12:44 AM | #6 |
Rep 33
Wow, pricey
Why the E46 M3 aluminum radiators won't fit the Z4M?! Like: https://www.turnermotorsport.com/p-3...inum-radiator/ or https://www.turnermotorsport.com/p-3...inum-radiator/ Last edited by 1zpower7; 10-25-2022 at 12:50 AM.. |
10-25-2022, 05:05 AM | #7 | |
Rep 801
2008 E86 M coupe
10-25-2022, 05:10 AM | #8 |
Rep 33
I've contacted Mishimoto and they told me that this will fit my Z4M:
https://www.amazon.com/Mishimoto-MMR.../dp/B0195YTE7G I've not yet sure which one of the CSF rads is compatible. |
10-25-2022, 03:51 PM | #9 | |
Rep 801
Sorry for the mix up. Looking at that Amazon ad I would say that it is identical to the CSF rad that I bought, right down to the look of the welded on flanges, it may be there is one manufacture that made them for both Mishimoto and CSF but CSF has dropped the rad from their catalogue due to lack of sales. I'll dig back in my old pics and see if I can turn up a pic of the CSF rad.
2008 E86 M coupe
10-26-2022, 07:20 PM | #10 |
Rep 14
Drives: 2007 Z4 M Roadster
grannyknot999.00 |
10-26-2022, 10:09 PM | #12 |
Rep 2,929
That's your firewall doing that. Or maybe your computer is forbidding you from modding your car?
10-27-2022, 03:12 AM | #13 | |
Rep 597
10-27-2022, 07:21 AM | #14 |
Rep 490
I’ve been using the CSF 3055 on my track car Z4MC. It fits and functions fine. I did not use the factory oil cooler and suspect that this may be the issue with this radiator. Not sure it has the mounts for the under radiator oil cooler.
10-27-2022, 01:32 PM | #15 |
Rep 1,379
I am using the CSF 3055 and using the factory oil cooler. Fit is basically perfect... i just need to get one longer screw because the CSF rad is a bit thicker.
07 Z4 M Coupe AW/IR |
06-13-2024, 11:01 AM | #16 |
Rep 71
bumping this thread, I checked real oem and the part number also reference non-m e46. Has anyone used and can confirm a non-m full aluminum radiator fits with or without issue? I ran Koyo in my e46 m3 and have been happy and would like to use the koyo non-m full aluminum. Wanted to see if anyone has tried a non m radiator.
Thanks! |
06-13-2024, 09:10 PM | #17 |
Rep 16
