New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      05-12-2024, 08:34 AM   #1
cinellipro
cinellipro's Avatar
Drives: BMW Z4
Greetings,
Has anyone installed 265 or 275 width tires on to their 8.5 rims? I like tread width.
I know rims are designed to have specific range of size tires, and deviating from that can affect tire wear and handling. In the past, I've installed wider tires with no adverse effects on tire wear and handling for "my driving."
I know me considering wider tires is an indication of a genetic deformity or communistical thinking.
Getting past all that, any one out there with wider rear tires? Any photos? Thank you.
Cheers!
      05-12-2024, 10:39 AM   #2
B21
B21's Avatar
167
Drives: E89 Atacama Yellow 35is
8.5 j is too narrow for a 265 under any circumstances related to an E89..
So it’s not clever , would void insurance if so found and illegal in certain jurisdictions..
Apart from that it’s fine !
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0
Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886
      05-14-2024, 09:57 AM   #3
Drummer$Dude
Drummer$Dude's Avatar
Drives: 2009 BMW Z4 E89 35i
My current setup is:
Front tires = 245/35R18
Front wheel = 8.5x18 ET35
Back tires = 265/35R18
Back wheel = 9.5x18 ET35
2009 BMW Z4 35i
2009 Infiniti EX35 Journey AWD
2017 Lincoln MKC AWD
      05-20-2024, 07:11 PM   #4
proboner
Drives: 2003 Z4 3.0 6-speed
Just to note, if you care about handling at all, a good rule of thumb is to keep the tread width at or 0.5" smaller than the rim width. A 275 width tire has a tread width roughly a full inch larger than the rim width. Gonna be rolling all over those tire shoulders before you firm up and the car actually turns.
