Originally Posted by Eau_Rouge111
Hi, will not work...one of the posts per the link of my discussion I had with the gentleman who told me not to pursue that route mentions mentions the e92 rotor...you will need a 6.8mm spacer to sit in between the hub and the inside of the rotor mounting surface to get the rotor not to touch the trailing arm.
Basically it's a big brake kit or the Porsche 996 conversion...those are our choices with the Z4M
Thank you for clarifying this!
