Originally Posted by Mirko
The turn signal's were only on in one of the pictures cause I turned the light switch to the first position. Otherwise my car is coded to show only the angle eyes as the day time running lights. In North America we are mandated to have the turn signals on when the lights are on. In Europe and I suspect Singapore you don't have to have them on. Did your turn signal lights turn on after installing the LED bulb or were they an option you could turn on before?
You are right that there aren't such regulations in Singapore, so my turn signals were never on regardless of which position the light switch was in. My AEs are not programmed as DRLs either, and will only activate when the head lights are on. The turn signal only came on after installing the LED bulb. The other side with the stock bulb remained normal.
Tomorrow I'm gonna turn on my lights with just the back cover removed, and see if the turn signal is on. Will report back.
