      01-22-2017, 12:57 AM   #17
GuidoK
#buildnotbought
GuidoK's Avatar
1353
Drives: Z4 3.0i ESS TS2+
Originally Posted by dre99gsx View Post
I went and just ordered a standard rear rotor. I didn't order the 335i rear calipers from the junkyard (just front).
You still need a different rear caliper. The stock caliper goes up to ~300mm, so a 325mm disc will fall out of the pad's range (and probably touch the caliper).
Z4 3.0i | ESS TS2+ | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers | Sachs performance clutch
