      01-21-2017, 10:46 AM   #11
GuidoK
#buildnotbought
GuidoK's Avatar
10644
Drives: Z4 3.0i ESS TS2+
^inner diameter for the parking brake is 185mm on those rotors, so you have to work around that. There are a few ways for that.
Everything over 300mm on bmw has a 185mm parking brake.
And the 135i disc is still about 3mm off in offset compared to the z4 disc. This could be corrected though.
The strange thing is that the brembo catalogue displays different sizes than the ate catalogue (in offset).
