Decided I needed to wait on the pump to make sure I would have no clearance issues, so moved over to making room for my oil tank. I am going to have the oil tank sit in the engine compartment like OE systems. Less plumbing and since we don't have a trunk, this is the only option to keep it out of the cockpit.
A 3 gallon tank should fit nicely once the cabin air box is removed.
Work in progress, but here it is so far.
Next up is to make a patch panel to weld in and plug that rectangle hole. I'll lose my nifty cabin vents. Also need to make a fence across the top to seal to the underside of the hood.
