Originally Posted by eggman51
Thanks very much for the reply. I think I will make that same modification as you did. I might try run extenders through the hole. Different brands of suspension seem to have different methods of adjustment, but your mod seems to make the most sense. If returning back to stock those plastic parts can likely be found cheaply.
Do you think extenders run through those would interfere with top operation?
Thanks again for the reply.
Eamonn aka eggman
I have Fortune Auto 500s on my car and did utilize their 9" extenders. They didn't hamper top operation. I tucked them in between the top and parcel shelf, however every once in a while they would come untucked and rattle against the rear window or something else. I did remove them for this year (mostly because I was an idiot and stripped one of the set screws) and just use the standard adjustment knobs now.
