      05-06-2019, 02:20 PM   #2
kyriian
kyriian's Avatar
885
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
Originally Posted by txguy1986 View Post
I am e newbie BMW owner and my Z4 E85 came with 67k miles on it. The front passenger wheel squeaks when I first apply brake pressure. I have done brake jobs before, but never on a BMW. Is there anything unique to BMW when doing a front brake job I need to be aware of? Any suggestion pn good pads. I don't intend on running this car that hard. Just daily cruiser.
There isn't much difference to any other car, I just finished my fronts and about to do the rear
1)grease those slider pins but not so much, it can get gummed up too if you use too much
2) you will need metric allen keys and a 6" C Clamp for sure at bare minimum
3) Rotor screws can get stuck and they are a complete pain. I had one round on me and end up drilling the head off. Soak em with liquid wrench
Other than that, there is not much else left.
Personally I use Stoptech Sport, a good mix of performance use. It's not a track pad and it can handle a little heat as well but it also does not squeal or have cold bite issues when its cold out.
Rotors, use Zimmermann or use the site sponsor getBMWparts for OEM
Revolution of our Times
I will return to the track, one day.
