Originally Posted by Eau_Rouge111
Can't make it...work...plus I have this clunking coming from the rear end since I had the kw v3 kit installed...like once in a while metal on metal type thing (loose shock? loose sway bar?)...going to go by process of elimination over the next month to figure out what's going/stop it...I'll have it ready for an Aug/Sept cruise tho
Too bad, it's been too long! I would first check the bolts on rear shock mounts.
