      01-21-2017, 10:00 AM   #8
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Originally Posted by dc_wright View Post
The 3.0si gets a larger caliper and rotor from the E46 330i for the front. The rears are the same for the 3.0i and 3.0si.
There's also a one piece cross drilled rotor option from the 330 that also fits the 3.0si since the 3.0si front brakes are actually 330 calipers and rotors. Obviously it's heavier than the two piece rotor, but it's also quite a bit cheaper since you can get it from multiple aftermarket sources.
Is the hub assembly the same? Any ideas?
