      11-16-2017, 08:15 AM   #44
dre99gsx
Drives: 1994 Toyota Supra
Ok - being that the Z4M front rotor fits the 3.0si, and the 335i front caliper fits with fairly good and even tolerances, does anyone have any photos showing that the Z4M front caliper can/can't fit the 3.0si?
I've read some posts saying it can't, but there was no measurements or actual data to show this (seems just hearsay). Can anyone positively confirm?
Reason I ask - I'm looking to piece together some other components for the front, and knowing what can/can't fit will help me determine what else I can swap over. If a Z4M caliper can fit up front, then I can follow some of the E46 M3 upgrade paths for the front system without issue.
I may be able to mix/match parts from Stoptech to move up to a 355mm system knowing this info. Since no one makes a 355mm upgrade to the 3.0si (or E46 330i from what I've seen), I may have to piece something together.
Am I not happy with my current brakes? No. Why do I want to do this? Because Racecar
