      11-09-2017, 08:58 PM   #40
3002 tii
3002 tii's Avatar
2286
Originally Posted by GuidoK View Post
^afaik the ID of the rotor hat is the same (both 160mm, so the 'small' bmw parking brake.
But the depth of the rotor hat is afaik much deeper on a z4 (so the rotor has a different offset).
Its because the z4 has a different bearing flange at the rear (and the z4 has thus a wider track at the rear)
Makes sense, I specifically recall noticing how the rear rotor hats appeared so much taller than other cars I've had
Follow for latest mods
