Originally Posted by Jackal
Originally Posted by XMetal
Front is fine. You'll need a 10mm spacer for the rear
Thanks for the reply. I was re-reading all 20+ pages here to find commonalities and be positive. I have read that if I use camber bolts and go to -2 degrees I may require a 5mm spacer up front for clearance on the suspension, but I'll cross that bridge when I get there.
Thanks again.
That may be the case if you add cambers. My 19x8.5 et 35 wheel wrapped with 245 tire cleared the strut with plenty to spare. No fender rub either. I'm on stock strut and camber.
