Originally Posted by rockstar93
TBH the audio quality is not great in the Z4M, and using the AUX jack seems even worse so I barely use it.
To my lame ears, the Carver setup that's part of the Premium package sounds pretty damn decent, especially considering the crappy environment it's got to work with.
Just today I was out cruising with SiriusXM streaming through my iPhone, connected to the aux port via a Lightning-to-aux cable. I ASSume the aux cable has to contain a DAC - that's really the only place the digital-to-analog conversion could be taking place. I have the streaming quality set to max in the Sirus app, which is supposedly 320kbps - or about 6-8x better than the. satellite stream. It sounds fantastic. Unlimited data on my T-Mo plan so no worries there. Important to me because I live in the sticks, and there are literally zero FM stations within range that I want to listen to.
This is the cable I'm using - $18.49 from Amazon:
https://goo.gl/MRPTDo
