Originally Posted by stephenkirsh
I'm applying, by hand, what I assume is about 10NM of force; very very low.
I wouldn't trust my fingers here
Is there anything else in this area that should be checked?
I would double check all other bolts around VANOS in case they were overtorqued too.
Also I'd (and I did on mine) use carb cleaner on oil passes in the solenoid block.
