I'm also running Stoptech Trophy ST40 355mm front and rear. No issues. Ease of pad fitment is a big benefit as is the cost.
As for wheel fitment, I also can't comment on OEM wheels. I can verify that 17" x 9.5" Apex ARC-8 et35 wheels do fit. You need a 5mm spacer in the front to clear the spokes.
I am having issue with Hawk DTC70 pads. I'm getting some fade under really hard braking. When these wear down I plan to switch back to PFC11. The Hawks are cheaper and easier to get, but I like pads that don't fade...
