Originally Posted by AK72
Esthetically I think your biggest issue is the wheel gap. Also, a different brand of tire will have different sidewalls design, so running a 275 Continental, Michelin, Dunlop, Falcon, Etc will all yield different results as some are more square. What is the offset on the rear?
I'm running a 275/30 Firestone Firehawk Indy 500 on a 19x10 ET 38 with a 15m space. I rub the outside face of the tire under really hard compression (on track only) so going down to a 12 or 10mm spacer will possibly fix the outside rub on this tire but not sure if I'll rub on the inside.
PS I have a set of H&R coilovers I used for about 10k km if interested.
