Originally Posted by EMagnuson
Matt,
Great to hear that it is not a rod! I was worried for you after all that work that you put into it. Best of luck with your continued build and with your upcoming move!
-E
Thanks!
Because I'm really good at being frugal and I have to remove the headers to install a helicoil in the head, I decided to avoid ongoing fights with exhaust header leaks by pulling the trigger on a set of SuperSprint stepped headers and stepped section 1 pipes.
Which means, I suppose, that I have a set of SuperSprint section 1 pipes with about 4 hours on them for sale. Labels aren't even fully burned off yet. $400?
edit: the Manzo headers will not be for sale, they're garbage but will look nice on the wall of my new garage.
