      10-15-2018, 02:53 PM   #1
dre99gsx
Drives: 1994 Toyota Supra
Talking Going off track sideways at 100mph
My ego took a bit of a beating this past weekend. Here is a prime example of why turbocharged is fun, but dangerous
Start at 12:54 - You'll see what going sideways at almost 100mph near a wall is like.
This section has a crest with a slight-left bend. I usually part throttle it in 4th and try to maintain 10psi boost (car boosts 23 full). The difference between 10psi and 23psi is about 5% throttle! Turbos like to spool indefinitely if given the chance.
Well, it did this time, and spun 90deg. Snap-oversteer with no time for correction. Traction control didn't even kick in since the rear was too light for any large difference in wheel speed from-to-rear.
I remember hitting the brakes right about when the car rotate slightly backwards, hoping I could hold it in that position and go straight and not into the wall. I was VERY lucky.
3GFX722.50
longress104.50
Mirko182.00
