Originally Posted by GuidoK
Was it difficult to reroute the battery wiring? or are all cables long enough for the z4m location of the battery?
And the amplifier wiring (I see you have the dsp amp). Are you relocating that to the z4m battery harnass as well?
I also see you have the digital interlink in your amp. Do you have hifi DSP with navigation (large screen) or without?
And your evap charcoal container. Did you relocate that also or not?
Do you have more pictures?
I routed the battery cable through firewall hole that was already there. The DSP cable is not long enough so I have it just sitting on the side for now until I figure out a way to mount it (I do have it connected and working). I do not have a navigation screen
Evap charcoal filter was removed. I'll provide more pics once I clean it up a bit.
