Use the plug on the opposite side of the batt from the the vent hose.
The registration tell the computer the battery is new so the charge characteristics are different from an older batt. Your car is not that smart and does not need to be registered, which is a good thing.
BTW, you may need to reset the windows if they don't drop ~1/4" when you open the door. This happens anytime the battery is disconnected.
