Originally Posted by SwissArmy
Removing the radio is not a daunting task, thankfully.
You just need to remove the vents (two tabs at the top that depress using a flat head screwdrive and pull out)
Then two phillips screws holding in the radio. Once it's out, leave the cables connected. Aim the radio downwards and press eject and try to use gravity along with the motor to get it out.
Else, try needle nose pliers?
Worth a try!! Thanks very much!!!
