Originally Posted by Willy Sea
As above, a typo crept in its a 2010 E82 chassis
Hi there,
That simplifies things quite a bit! The E82 1-Series utilizes higher offsets compared to most other BMW chassis, so the wheel sizes you listed will not make for an ideal fitment. For a 8.5" and 9.5" staggered setup, I would recommend the following:
Front: 18x8.5" ET45 with 235/40-18 tires
Rear: 18x9.5" ET58 with 265/35-18 tires
-Available only in ARC-8, EC-7R and EC-7 designs.
-Direct fit with stock suspension, lowering springs, and a variety of
aftermarket coilovers. 5mm front spacers required for certain aftermarket
suspensions, see below.
-245/35-18 front tires can fit with 5mm front spacers and approximately -1.5
degrees of camber or more. Larger front spacers may be required for certain
aftermarket suspensions, see below.
-255/35-18 front tires can fit with 5mm front spacers and approximately -2.5
-275/35-18 rear tires can be used with negative camber and/or rolled
fenders.
If you would like to check out our 1-Series specific fitment guide, you can do so via the following link:
https://support.apexraceparts.com/hc...-Fitment-Guide
Please let me know if you have any questions!
-Geirsen
