      06-16-2018, 08:40 PM   #135
GuidoK
#buildnotbought
GuidoK's Avatar
10883
Drives: Z4 3.0i ESS TS2+
Insane power for a z.
Not even going to bother if its whp or crank.
Is this kind of power (and the huge torque increase at 3,5-4,5krpm) possible to put on the road decently or would 4wd be a benefit? Within 1000rpm the torque more than doubles, so I can imagine that that can be quite dangerous if you're not prepared for that.
Do you have an afr graph?
