Originally Posted by Cyclops
Just wonder if this would work? I think Rears would be OK but fronts will rub and would require some camber work?
19x9 +20
9x10.5 +25
should be ok with proper tires and some fender rolling,
im currently running 18x9.5 ET22 with 225 40 18 in the front and 18x10.5 ET22 with 255 35 18 at the back on H&R lowering springs with 14mm rear upper spring pads. All camber setting stock. Lowering springs and fender roll only
