Originally Posted by RossBMWZseries
possible window issues; window motor or window regulator, start by checking the fuse.
As for the smoke, does your Z4 have the N52 engine? There's recalls for this. I had it taken care of under recall on my 328i (N52). Basically, a small piece of plastic inside the dashboard gets burned and can cause a short, worst case scenario, a fire. It smokes through the vents and the smell is too strong, can't miss it.
I'm pretty much a newbie when it comes to cars, how would I check if I have that engine? It's a 2.0L
