Originally Posted by Duncan.B
How did you get on with the rtd shifter ? I've just picked up my z4m amd looking at options for a ssk. Any pros and cons would be great 👍🏼
I would not install any other SSK in my car after using the RTD shifter. It is pricey, but can be installed without permanently modifying the car, and can have the shift boot installed over it to finish it nicely.
I have driven the car extensively on the road and track and the RTD is a great shifter. The CAE ones are probably a little better, but they are more expensive and require bothering up the car permanently, and I don't know if you can get the shift boot back on over the CAE.
I also did engine and transmission mounts which I would highly recommend if you are going to the trouble of installing a chassis-mounted shifter.
Good luck!
