      11-19-2018, 04:44 AM   #2
GuidoK
#buildnotbought
GuidoK's Avatar
10941
Drives: Z4 3.0i ESS TS2+
Afaik bmw made style 224 only in 1 widht set (8"front, 9"rear)
Are you SURE you measured the correct way? within the bead seats? (that means taking off the tyres)
If I look at your picture the tyres look pretty puffy on there but its not the best picture to judge. More detailed pics, taken in the line of the rims, (especially from the front wheels) would be better in this case so people can actually see and compare.
