Originally Posted by pungo
Try to disable it with NCSExpert modifying the KMB module by setting the following:
KBUS_RDC - K-BUS TIRE PRESSURE CONTROL (RDC) = nicht_aktiv - not enabled
AKUSTIK_ASC - AUTOMATIC STABILITY CONTROL (ASC) WARNING GONG = nicht_aktiv - not enabled
Pungo, is this something you've done? This would be great if it works.
