      05-18-2019, 11:21 PM   #67
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Originally Posted by RossBMWZseries View Post
Thanks K9. I removed the panels off the car, seemed easier. I did the double sided tape so the CF skirts are on the panels now. I just need to screw them in. Question; did you screw the skirt with the panel only or did you also screw it in to the actual body? How long were the screws you used?
Hey Ross,
You have about half an inch of clearance before hitting the body. Since the tape will hold the side skirt very well, the added screw is for additional security. Just use the self tapping screws that will protrude past the CF extension and the skirt with half an inch left. That will be perfect. Then all you have to do it to put the side skirt back on.
HTHs
FB Group-- > fb.com/groups/z4group
FB Page-- > fb.com/Skyermotorsport
