Oversteer:
When the rear tires slip out, you want to turn into the slide. Lift off throttle
Pause
Correct.
So, if you're going into a left hander, and the car slips out...turn RIGHT. If you continue to left you'll loop the car. There is no correct amount of angle, but you want the tires to still maintain direction of where you want to go. Once you feel the rear tires get grip again be ready to correct the steering angle to avoid going way right. Makes sense?
Understeer:
SLOWLY lift off throttle and let the tires regain grip. Releasing quickly will cause you to snap oversteer.
