      07-21-2020, 08:41 PM   #4
BobR07Z
Drives: '07 Z4
Originally Posted by rsutoratosu View Post
Thats one of the reason I haven't done mine.. I couldnt find the info on bleeding also.
Not sure if you replaced the motor yet or not but I recently did and will tell you to fill the reservoir 3/4 and manually raise and lower the top once or twice checking the fluid level and then run the motor as it will self bleed out. Just keep an eye on the fluid level at least 1/2 - 3/4 filled at the end.
Good luck!
