      09-20-2019, 04:26 PM   #40
bimmer456
Drives: 340i
I had been switching to comfort around police even though I never got stopped for exhaust. I imagine if it's popping and banging or through an under pass they might do something but that hasn't happened either. Only the fine is going away though presumably you can just unplugged the mppsk so it doesn't open in sport when you get it tested. Or just have it tested in comfort.
It's in comfort by default, so there would be no reason to test it in Sport Plus.
If the testing procedure involves revving past 4K then it will have to be unplugged to confirm it's fixed
Maybe go back and reread what I posted.
RPM's have nothing to do what I posted.
Revving past 4K in comfort mode will cause the valve to open so it will be louder. They may want to test the exhaust in sport mode also to see if it complies.
