Originally Posted by Jumbosock
Take pics. Maybe it still does need some trimming. If it isn't seating in properly maybe that's allowing the side skirt to slip downward??
No it actually didn't need trimming, after comparing the two it looks like the hook/clips that run along the top edge were shorter then the ones on the original skirt. (or they've just been compressed after a couple years?) It fit, but it just wasn't staying clipped into place. We put a shim under the front most one to help hold it up and keep it there, we'll see what that does.
Edit: If anything it might look like the whole thing isn't quite sitting forward enough? I didn't install it so I'm not sure how much front to back play there is and I don't want to try to take the whole skirt off at the moment because I don't have any replacement bayonet clips.
