      10-12-2018, 11:25 PM   #10
3002 tii
3002 tii's Avatar
2300
Originally Posted by GORDON.M3 View Post
I'm having a hard time understanding how you wired it directly to the DME, the diagram only shows 1 A74 unit being used.
And two wires from the A74 unit directly going into the yellow wire from the DME connector?
The second picture was drawn up by a74 and is intended to show which wires from DME correspond to which wires on the rear o2 but you’d essentially have to replicate the install for the 2nd rear o2.
If you read my 1st post I actually describe which wires I used when installing both sims (and you can cross reference against the pdf to see which harness I used).
Follow for latest mods
