      12-20-2018, 10:48 PM   #5
GuidoK
#buildnotbought
GuidoK's Avatar
10871
Drives: Z4 3.0i ESS TS2+
Originally Posted by RossBMWZseries View Post
The piece is TRUE carbon fiber. It's not dipped as Guidok pointed out and it seems to be more than 1 layer of carbon fiber, you can see it on both inside and out. I'm sure it does have fiberglass composites of course.
Then you maybe have another model. And I'm not saying its dipped, but that its either dipped or coated with a very thin CF layer (1 ply)
The current schmiedmann one looks like this on the inside:
Thats not CF but some very coarse (glass?) fibres. So the main structure of the thing is clearly some glassfibre or something and there isnt any CF that gives significant strenght to the structure.
Also on that broken one you also immediately see the white glassfibres.
Maybe I should strenghten it from the inside as a precautionairy measure. It does reduce the ground learance considerably...
