      03-15-2019, 09:09 AM   #4
WedgeSalad
Drives: 2018 F87 M2
Originally Posted by RMachuca3d View Post
To get enough accuracy you need an expensive rig+software, I'd never rely on consumer available products to use in an actual production environment, unless i was scanning organic things, when it comes to mechanical scans you need precision. Laser based scanners are probably the best thing for now, those run in the thousands at minimum.
Yeah that is what i found out. There are a couple at the $5-6k mark but i may try and rent something and see how it goes.
