      07-16-2019, 02:26 AM   #6
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Originally Posted by eggman51 View Post
Here is the door clearance, it's about 1mm, though I had to use a spacer to bump it over.
Untitled
Here is how the mounting looks, showing the aftermarket E30 switch.
Sparco QRT seat installed in BMW Z4M Roadster
This is how it looks in the car. Good match for the stock seat imo.
Initial impressions of the seat are very favourable. Very comfortable, nice solid feeling.
The exterior bum of the seat is wide and restricts adjustment positioning. I need to mess with it, but in this configuration - with the stock sliders - I can't drop the back of the seat down beyond the first mounting position (highest). It bumps into the stock rail mount. From my initial driving impressions, I think I might want to drop the rear down 1 or 2 holes, so I will need to experiment with that.
The stock seat belt receptacle location is not a problem, you can see that the seat does not interfere with it in a way that would change the seat belt position.
I knew I would end up doing this at least twice to get the seating position right, as well as install the harness. I will make a better write up second time around.
Cheers,
Eamonn
Good looking setup and Suits the roadster really well! Any play side to side? I had that with my VAC sliders and could not get rid of it, so just bolted to the floor.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
