      05-07-2019, 07:36 PM   #3
3002 tii
3002 tii's Avatar
2282
Just have an open mind, listen to your instructor. Try not to follow the car ahead of you but look ahead to the next corner. Smooth inputs, slow in fast out!
Car prep wise everything sounds good. Next time I’d use a higher temp fluid as I’ve been able to cook ATE. Castrol is expensive but well worth it in my opinion and probably averages out with other brands since you can go longer in between flushes.
Follow for latest mods
