Getting ready to install the Turner fixed plates, once installed are you still able to adjust the camber or are you stuck with whatever comes out of putting them on. Was speaking to someone and I think they are misinformed, said that the plates being fixed will be locked into whatever it ends up being. Example: if one side is -1.6 and other side is -2.0 there is no way to adjust to even them out . Not sure they are correct. Thoughts ?
